Measurement Studio for VB6
CWGraph and SSTab ctrl
I'm using several CWGraph controls and a SSTab ctrl on 1 form.  The graphs are updated by timers every 5 seconds.   There is an intermittent problem.   When I click on a tab, then click back on a tab containing a chart or charts, the data is not plotted and the chart doesn't update until the 5 second timer interval has elapsed.
Does anyody know what's going on?
Curt
(6,212 Views)
Curt,
I was unable to replicate your issue on my machine.  How many tabs do you have?  How many charts are on each Tab?  I created a simple application with an SSTab Control with a Graph on the first two tabs.  When I start the execution, the Charts are updated every 5 seconds from a timer.  When I click between tabs, each chart properly displays the data.  I have attached my project below.  As a workaround, you can try to call a refresh for the currently displayed tab.  Try inserting code like this:
Private Sub SSTab1_Click(PreviousTab As Integer)
    If SSTab1.Tab = 1 Then
        CWGraph1.Refresh
    ElseIf SSTab1.Tab = 2 Then
        CWGraph2.Refresh
    Else
        CWGraph3.Refresh
    End If
End Sub
If this does not work, try to replicate the issue with as small of a project as possible and post it here.  I can take a look at the code to see what may be going on.
Good Luck
Tyler T.
(6,198 Views)
Hi Tyler,
Thanks for the reply.  I found a solution to my problem.  The data was being plotted but was being displayed as a veritcal line on the
left side of the chart(s).  The X axis on each chart is set to autoscale in the properties page.
I added 'Graph(j).Axes(1).AutoScaleNow' to the tab click event and things seem to be working fine
Curt
(6,182 Views)
