Measurement Studio for VB6
CWGraph in delphi
Hi every one
am Working with an application in Borland Delphi 3... and I need to implement a Graph (Voltaje Vs Time) by using GWGraph1.PlotXvsY function (Measurement Studio) but when implement this function am  receiving the Error: Project DL_MAIN.exe raised exception Class ERangeError with message 'Range Check error' Process Stopped. USe Step or Run to Continue.
Does anyone know if am missing something ?
No Errors when Complie.
This function has the followings parameters: CWGraph1.PlotXvsY(xData: OleVariant; yData: OleVariant; bchartPerRow: OleVariant);
Var
     v, t: Integer
     TimeOle: array[1..1000] of OleVariant;
      VoltOle: array[1..1000] of OleVariant;
begin
      For v:= 1 to DatVolt[v] Do
      VoltOle[v] : DatVolt[v];
      For t:= 1 to DatTime[t] Do
      TimeOle[t] : DatTime[t];
      CWGraph1.PlotXvsY(TimeOle[t], VoltOle[v], False);
end;
Thanks for your help in advance..
(7,877 Views)
Hi Delt Measurment Studio doesn’t is not officially supported in Delphi.  Some issues could be solved with the update of Delphi 3  (Version 3.0 (Build 5.83)). Some of this errors are caused by the way they called the ActiveX.
Best Regards
Benjamin C
Principal Systems Engineer // CLA // CLED
(7,832 Views)
you can use this code in delphi to plot SINE function ( Hope this will help anyone who use Delphi and NI components)
var
  x:  OleVariant;
  y:  OleVariant;
  I: Integer;
  XData:Variant ;
procedure ........
begin
x:=VarArrayCreate([1,40],varDouble);
y:=VarArrayCreate([1,40],varDouble);
for I := 1 to 40 do
 begin
x[I]:=I;
y[I]:=sin(I/2.0);
 end;
  CWGraph1.PlotXvsY(x,y,True);
end;
(6,494 Views)
