Measurement Studio for VB6
CWIMAQVision.CreateCWIMAQCalibrationPoints error
CWIMAQVision.CreateCWIMAQCalibrationPoints returns the error "Object doesn't support this property or method". Any Ideas?
Bill Swartz
Optomec
(8,317 Views)
Hi Bill,
Which software are you using and what version?  It seems as though you are using Visual Basic.
What is your ultimate goal in your application?
I recommend you have a look at the help file located at Start >> Programs >> National Instruments >> Vision >> Documentation >> NI Vision.
In that folder there is a file called cwimaq.chm, which is a help file you can use for using Vision functions in VB.
If you can provide me with more details I can help you more.
Typically that error is when you are trying to call a function that doesn't work for that object.  The help file should give you more information about what functions you can call.
Rishi L
(8,310 Views)
Hello Rishi,
Yes, I am using VB6. I am familiar with the help file "
cwimaq.chm". Can you show me a short code sample demonstrating the proper usage of "CreateCWIMAQCalibrationPoints"?
Bill
(8,303 Views)
Hi Bill,
The examples for our Vision tools in other languages are located here on your system:
C:\Program Files\National Instruments\Vision\Examples\
Specifically the VB examples for CalibrationPoints are here:
C:\Program Files\National Instruments\Vision\Examples\MSVB\2. Functions\Calibration
Rishi L
(8,292 Views)
Hello Rishi,
I am also familiar with the examples. The function "CreateCWIMAQCalibrationPoints" does not appear in any example. So I repeat the question.
Bill
(8,289 Views)
Hi Bill,
I noticed that you posted your code on this thread:
http://forums.ni.com/ni/board/message?board.id=230&message.id=3837
Because my next question was to ask to see your code I'm going to focus on the other thread.
Rishi L
(8,271 Views)
