Measurement Studio for VB6
CWIMAQVision.Threshold (Visual Basic)
Is there any other methods other than the one above, as this sets pixel values outside the given range to 0. It would be nice to have a function that leaves the pixel values outside the given range unchanged.
(3,112 Views)
Heather,
You could use the Multi Threshold2 Method, with the replacement set to False. By setting replacement to False, this will allow you to specify the two ranges you want to keep the vaules in, and the rest would be set to zero.
Best Regards,
Chris D
NI Applications Engineer
(3,112 Views)
