Measurement Studio for VB6
Can I set individual channel gains on a SCXI-1100 A/D?
I have a SCXI-1100 Mux that I will be measuring various transducers with. These transducers have different outputs, and thus need to use different gain settings. Can I set gains for each channel independantly? I tried using the .UpperLimit and .LowerLimit methods, but the gain and range that I read back were always zero.
(3,411 Views)
Eric,
Your SCXI-1100 module multiplexes all channels into the same channel of your DAQ board, so in this case you can only set the gain for your DAQ board channel in which the 1100 readings are multiplexed, in an overall manner.
Good luck!
Nestor Sanchez
Nestor
(3,411 Views)
