Measurement Studio for VB6
Can't Install Measurement Studio 6.0
I have Labview 6.1 installed on the computer and I get an error saying that " Measurement Studio Cannot be installed on a system with Labview 6.0.0 please upgrade to a later version"
(3,162 Views)
First, make sure that you do indeed have LabVIEW 6.1 and not 6i (which is really 6.0.0). If you do, you can bypass the LabVIEW version check. Start a command prompt (usually Start>>Programs>>Accessories>>Command Prompt) and type the following command:
msiexec /i X:\measurementstudio.msi EAGLE=1
(replace X with the drive letter of your CD or otherwise specify the location of measurementstudio.msi).
Let me know if that doesn't work.
Tony
(3,162 Views)
