Measurement Studio for VB6
Changing ActivePointer.Index from code is impossible!
The ActivePointer.Index is a read-only property.
So how can I change the active needle if I've set two pointers in a knob control?
It seems that is impossible in this version of cwui.ocx 3.0.1
(3,220 Views)
Like this:
Set CWKnob1.ActivePointer = CWKnob1.Pointers.Item("Pointer-2")
Best Regards,
Chris Matthews
(3,220 Views)
I am having a similar problem with a slider. I have a slider with three pointers. When I try to use the activepointer property to set the activepointer it assigns the value of item(1) to the active pointer. That's not what this is suppose to do according to the documentation.
cwsExposure.ActivePointer = cwsExposure.Pointers.Item(1)
Paul
(3,220 Views)
