Measurement Studio for VB6
Changing the slider extremes programmatically
I haven't found the manner programmatically change CWslider minimum and maximum values in VB, as usually there are member variables for changing min and max in different sliders.
(3,012 Views)
The max and min and other scaling properties are on the Axis sub-object of the slide. So, if CwSlide1 is your CWSlide object, you could do the following to set the range to [-10, 10].
CWSlide1.Axis.Minimum = -10
CWSlide1.Axis.Maximum = 10
David Rohacek
(3,012 Views)
