Measurement Studio for VB6
Changing to Local mode
I am using   Excel VBA for instrumentation with visacomm. I have sissues taking back the instruments to local mode after completeion of the data collection. For example, the bleow code is for  Recalling a state  keysight power meter N1912A and move to local mode. For some reason this is not taking back the power meter to Local mode.
Dim PMO As VisaComLib.FormattedIO488
Set PMO = New VisaComLib.FormattedIO488
 Set PMO.IO = ioMgr.Open("PMO")
PMO.WriteString "*RCL 4"
PMO.WriteString "SYST:LOC" <As per manual this command takes back to Local mode
PMO.IO.Close
Set PMO.IO = Nothing
Leyo
(6,251 Views)
What NI drivers are you using? If you are using NI 488.2, ibloc() looks like it will take the instrument back to local mode.
http://www.ni.com/white-paper/3847/en/
Maggie M.
Application Engineer
National Instruments.
http://www.ni.com/support
(6,192 Views)
Thanks. The Ibloc commnad work with GPIB communications. In my case I am talking to instruments from excel VBA using visa.comm. I am looking for a method to make the instruments local in this method.
Leyo
(6,189 Views)
I found the following document discussing Excel VBA and VISA COM, is this what you are working with?
http://www.keysight.com/main/editorial.jspx?cc=US&lc=eng&ckey=474172-1-eng&nid=-536900124.0.02&id=47...
You may want to follow up with the creators of VISA COM for questions on local mode.
Maggie M.
(6,171 Views)
