Measurement Studio for VB6
Computer reboots after running 5 samples
Hi
I have made a scripts thats open a running sample from a LC-MS. It then translate the XiC value from a chrommatogram in to a analog output voltage. The Output voltage is only changed from each new scan (ActualCycles). The scrips works fine to approx. 5 sample and then the computer starts to reboots. The CPU is running at approx. 100%. How can change the script so it be come more stabil. I'm using VB6 and DAQmx 8.5 on a XP computer. The DA converter is NI USB-6211. The Doevents have made it more stabil. Why?
part of the script:
Data_is_recorded:
    theAnalyst.ActiveControl = xicGraph
    Set Xicdata = xicGraph.SeriesColl.Item(1).DataObject
    Set theWF = Xicdata.GetWiffFileObject
    Actualcycles = theWF.GetActualNumberOfCycles(sampleIndex, 0)
    If Actualcycles = expectedcycles Then
    GoTo end_script
    Else
    If Actualcycles > lastcycles Then
    DoEvents
    Set DataPoint = xicGraph.SeriesColl.Item(1).DataObject
    thenumberOfDataPoint = DataPoint.GetNumberOfDataPoints
    Call DataPoint.GetDataPoint(thenumberOfDataPoint, theXvalue, theYvalue)
    Dim taskHandle As Long
    Dim clockEdge As Long
    Dim sampsPerCycle As Double
    Dim desiredSampleClockRate As Double
    Dim resultingFrequency As Double
    Dim amplitude As Double
    Dim numSampsPerChannel As Long
    Dim numChannels As Long
    Dim errorCode As Long
    Dim errorString As String
    Dim sampsPerChanWritten As Long
    Dim XICVolt As Double
    '  Create the DAQmx task.
    Call DAQmxCreateTask("", taskHandle)
    '  Add an analog output channel to the task and check to see whether there is only ONE task.
    Call DAQmxCreateAOVoltageChan(taskHandle, "Dev2/ao0", "aoChannel", "-10", "10", DAQmx_Val_VoltageUnits2_Volts, "")
    Call DAQmxGetTaskNumChans(taskHandle, numChannels)
    If numChannels > 1 Then
        errorCode = -1
        errorString = "Please specify only one channel."
        Err.Raise errorCode, , errorString
    End If
        XICVolt = (theYvalue / 10000000#)
    '  Write to the desired channel(s).
    Call DAQmxWriteAnalogF64(taskHandle, 1, True, 10#, _
        DAQmx_Val_GroupByScanNumber, XICVolt, sampsPerChanWritten, ByVal 0&)
    Else
     lastcycles = theWF.GetActualNumberOfCycles(sampleIndex, 0)
     End If
    GoTo Data_is_recorded
end_script:
End If
Best regards
Peter
Message 1 of 1
(6,334 Views)
