Measurement Studio for VB6
Control Analog Output Signal Using NI-FP-AO-210 Module
Hello...I have a process where I need to control a Porter flowmeter PCIM4 box, which has a 0-5v input, this input changes the flowrate according to the voltage supplied.  Can I do this using a FP-A0-210 module?  Using the computer I would simply tell the module what voltage to output and the flowmeter would go to the rate specified. If so, is there a VB6 example on how to communicate with this module, specifically to tell it how much voltage to output? I appreciate any help you can give me!
Message 1 of 1
(6,519 Views)
