Measurement Studio for VB6
Counter Acquired_Data does not work?
I am using a PCMCIA board AI-16XE-50 which I think is now called NI6012E.
With Measurement Studio, VB6 and traditional NI-DAQ drivers.
Essentially that is what I am trying to do. I have ~450ms high signal
which turns low for 50ms and repeats. I want my visual basic to receive it
and act upon detecting a falling edge. When I run the test panels, the
counter counts these events accurately (actually twice the number
detecting both falling and rising edges), so in visual basic, I tried to
set up a simple application:
1) I included a counter on my form and configured it:
Measurement Type: Event Count
Counter: 1
Initial Count: 0
Use buffering: unchecked (I tried checking it and choosing 1 or 1000)
Clock: Source: PFI
Signal: 0
Edge: Count falling edges (or let NIDAQ choose)
Count Direction: Up
No gating and other things are default.
2) I put a start  button which when  pressed, I issue:
CWCounter1.Configure
CWCounter1.Start
3) I clicked on the counter icon and created this:
Private Sub CWCounter1_AcquiredData(Measurement As Variant, Overflow As Boolean)Text1.Text = Measurement
End Sub
(from examples in your pages)
4) I put a simple textlabel to display the result in (3).
5) I put a stop button which issues:
CWCounter1.Reset
CWCounter1.Stop
So, I was expecting that atleast in the buffered mode, after each count,
it should call the acquired data sub-function and I can act upon that
count.  Unfortunately, it never calls acquired data.
Am I wrong in my reasoning? How else can I achieve this effect? (I have
also tried a while loop and reading the signal one by one, did not work).
Ulugeyik
(6,037 Views)
Hello Ulugeyik,
There is actually a shipping example that can be used with your 6012E, does event counting using Traditional DAQ, Measurement Studio and VB.  If you did not change the defaults when installing NI-DAQ, it is located at: C:\Program Files\National Instruments\MeasurementStudio\VB\Samples\DAQ\Counter\DAQSTC Event Counting
Good luck with your application!
Micaela N
(6,020 Views)
