Home
Community
Discussion Forums
Most Active Software Boards
Measurement Studio for VB6
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Counter with 6601 DAQ
silvio
Member
03-19-2001
08:30 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I Cannot use counter 3 and 4 of a DAQ 6601 board in Visual Basic.
Someone know as configuring it in Visual Basic with ComponentWork ?
I Have to receive signal from four one-channel encoder but only two counter
work.
PFI 39 -> Counter 0 (work)
PFI 35 -> Counter 1 (work)
PFI 31 -> Counter 3 (don't work)
PFI 27 -> Counter 4 (don't work)
I think that problem is in the configuration of PFI31 and PFI27.
Sorry for language
regards
SILVIO
0
Kudos
Message
1
of 2
(3,402 Views)
Reply
Re: Counter with 6601 DAQ
Raecine Meza
Member
03-21-2001
10:35 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
If you're using the same code and properties for all the counter operations, there should be no problem. You might double-check your wiring.
Also test the counters in Measurement and Automation Explorer to make sure they are working properly.
0
Kudos
Message
2
of 2
(3,402 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
