Measurement Studio for VB6
Create a DVM with USB-6008?
I am looking to create a basic DVM with the NI USB-6008.  All I need todo is read a Digital voltage of ~1V continuously and display it in a text box in VB.  I have looked at the NI-DAQmx Digital input example code but does not show how to convert the input data into a visual text.  I have limited experience with VB and was wondering if anyone has a simple code that can do this.
Thank You
(4,983 Views)
Hello Kimon,
You can run the Visual Basic example located in the following folder:
C:\Program Files\National Instruments\NI-DAQ\Examples\Visual Basic 6.0\Analog In\Measure Voltage
When you install the MS NI-DAQmx.NET class Library, example programs of VB. NET are installed by default.
NI-DAQmx.NET Examples
You also can find detailed information in the help file located at:
Start >> Programs >> National Instruments >> NI-DAQ >> NI-DAQmx C API Visual Basic 6.0 Help
And also another useful link:
How to Set up a Voltage Measurement Alarm System
Good Luck!
Meri
(4,810 Views)
The Keysight U2741A USB multimeter flexibly operates as a standalone unit or as a modular unit in the U2781A modular product chassis. This notebook-sized USB digital multimeter (DMM) lets you carry powerful test gear in your bag along with your laptop PC.
(4,040 Views)
