Measurement Studio for VB6
Creating a Non-stop Continuous Digital Output
Hi all,
I'm trying to make a continuous digital signal that does not stop when the sub procedure that creates it ends.
I'm able to create a continuous analog signal that doesn't stop when its procedure ends by loading the necessary analog output task as soon as I pull up the .xls file, then writing values to a buffer, then stopping the analog output task, then using the WriteBinaryI16 command.
That code looks something like this.
publicStatus = DAQmxStopTask(publicAnalogOutTaskHandle)
publicStatus = DAQmxWriteBinaryI16(publicAnalogOutTaskHandle, DACwaveFormSize, True, 5, DAQmx_Val_GroupByScanNumber, buffer(0, 0), publicSampsPerChanWritten, ByVal 0&)
Can I use much the same procedure to output a nonstop continuous digital signal? For what it's worth, I'm using an PCI-6259 DAQ card that is connected to an SCB-68 connector block.
Thank you,
Armando83
(6,329 Views)
Hi Armando83,
Hardware timed digital output on a M-series device (62xx) can be a little tricky.  The M-series devices don't have a dedicated timing engine so you have to use an external clock, a counter configured to act as a clock, or share the sample clock from an analog task that is already running.  This process is called correlated digital I/O.
There are a number of VB examples on the the Code Exchange found at http://www.ni.com/community .  I've found one example that might be useful below, but I'm sure there are others that will be helpful to you as well.
NI-DAQmx: Correlated Digital Output in Visual Basic 6.0
http://forums.ni.com/t5/forums/replypage/board-id/230/message-id/5052
Josh B
(6,319 Views)
