Yes, I tried copying the CD to the hard drive, no luck.
I did have DAQ working on here, but from a nice big hard drive with all the
development stuff on it. I've tried copying the system directory, and the
Program Files/NI directory, to the microdrive and booting it, and although a
little rough around the edges (frequent errors about LVRT not being there) I
have got test panels up and they seem to be working. Once I have development
capability on it again I'll be able to see if everything under the hood is
working.
Dr. Craig Graham, Software Engineer
Advanced Analysis and Integration Limited, UK. http://www.aail.co.uk/
"Spencer S." wrote in message
news:5065000000050000001A170100-1042324653000@exchange.ni.com...
> Craig,
> Since the
installation keeps asking for the source CD, which is
> already in the computer, you could try copying all of the files from
> the CD onto your computer and running the installer from there. You
> may have already tried this, but it is another idea. Have you
> installed NI-DAQ on this computer in the past? It sounds like an
> interesting setup.
> Good luck with your application.
> Spencer S.
