Measurement Studio for VB6
DAQmxCfgSampClkTiming problem with "/Dev1/Ctr0Out"
Does someone know why I cannot use "/Dev1/Ctr0Out" as a source of External Clock ? The code is:
DAQmxErrChk DAQmxCfgSampClkTiming(taskhandle, "/Dev1/Ctr0Out", _
        cwRate.Value, clockEdge, DAQmx_Val_AcquisitionType_ContSamps, 100#)
But will cause an error of -89120: Soure terminal to be routed could not be found on the device, why? Thanks in advance,
Yingmai
(6,872 Views)
Hi Yingmai,
Are you generating a signal with Ctr0 that you are wanting to then use as a sample clock for another task on the device?  You should actually use "/Dev1/Ctr0InternalOutput" to internally route the signal you're generating with the counter to the sample clock for your task.
Andrew W
(6,865 Views)
