Measurement Studio for VB6
DAQmxWriteAnalogScalarF64
I am trying to output a fixed current to a single channel use VB6
My code is below.  I get no error messages but I also get no output.  If I save this task to MAX the current value saved is 0. If I change this and run it and I get the appropriate output.
DaqMxErrChk = DAQmxCreateTask("Task2", mytask1)
MsgBox ("Create Task" & DaqMxErrChk)
DaqMxErrChk = DAQmxCreateAOCurrentChan(mytask1, "Dev14/ao16", "ImaxLD1", 0, 0.02, DAQmx_Val_CurrentUnits2_Amps, "")
MsgBox ("Set Chan" & DaqMxErrChk)
DawMxErrChk = DAQmxWriteAnalogScalarF64(mytask1, True, 10, 0.01, Null)
MsgBox ("Set Current" & DaqMxErrChk)
DaqMxErrChk = DAQmxStartTask(mytask1)
   MsgBox ("start" & DaqMxErrChk)
(7,651 Views)
Clarify what you mean by, "If I can change this and run it and I get the appropriate output."  I'm not sure what you mean by this.  Not sure if this is a typo, but your code is: DawMxErrChk = DAQmxWriteAnalogScalarF64(mytask1, True, 10, 0.01, Null).  You may need to change that.
Sean
Applications Engineering Specialist - Semiconductor Test
(7,639 Views)
I am running the task two ways.
#1 : With MAX.  I need to manually enter the current set value since this value is not saved with the task.   I then press the run button.  This method works and I get output from the card.
#2 : With the VB code shown.  When I run this all the functions return 0 (no error) but I get no output from the card.  ("Daw " was just a typo when entering in this forum).
(7,626 Views)
It maybe the fact that you are using the DAQmxErrchk as a handle, and that you are not performing a boolean check.  See the attached example to verify syntax (it is for voltage, but it should still give you an idea of syntax).
Sean
(7,616 Views)
Accepted by topic author lls01
With some help from ni support I found this solution.  Last parameter in function call cannot be null
DaqMxErrChk = DAQmxWriteAnalogScalarF64(mytask1, True, 10, 0.003, ByVal 0&)
(7,598 Views)
