Measurement Studio for VB6
DaqmxRead VB6
Im new to Daqmx, Is it possible to read digital lines through vb6.
Im using usb 6509, from test panel i can see the bits on/off. I can control the bits externally. Is there a way i can read them through vb 6 code cos i need to perform more functions afterwards.
I used the following code. I would like the result in bits.
'create task for Reading digital signals from Dev1
    jStatus = DAQmxCreateTask("", taskHandle)
    jStatus = DAQmxCreateDIChan(taskHandle, "Dev1/port0/line0:7", "", DAQmx_Val_ChanForAllLines)
    'Start the task
    jStatus = DAQmxStartTask(taskHandle)
'read Port
    jStatus = DAQmxReadDigitalLines(taskHandle, 1, 10#, DAQmx_Val_GroupByChannel, readArray(0), arraySizeInBytes, sampsPerChanRead, numBytesPerSamp, ByVal 0&)
'close the channel
    jStatus = DAQmxStopTask(taskHandle)
    jStatus = DAQmxClearTask(taskHandle)
Hope im not confusing. Thanks for any help
(6,517 Views)
Hi rakoon,
When you install the DAQmx driver, there are Visual Basic examples that install.  Please navigate to Start»Programs»National Instruments»NI-DAQ»Text-based Code Support.  You an find many resources for Text-based code development.  There are analog, digital, and counter examples already created for this language.
Best,
Adam
Academic Product Manager
National Intruments
(6,495 Views)
