Measurement Studio for VB6
Displaying Multiple Plots of Data
How can I plot/chart 4 real time acquisitions on a single Graph. I have read App Note 150 (Several Times)
and can not make sense of it.
What is GenerateMultiChannelTempData(4, 800, 230#)?
What is the 230#?
Does the Multiplot property need to be true?
Thanks in advance for your help,
(3,611 Views)
GenerateMultiChannelTempData is an example function that returns a 2D array. 230# is a literal value with a # suffix, which in Visual Basic means that its type is double.
In short, the way you put multiple plots on the graph is to either a.) create a 2D array and pass it to the graph's PlotY method, or b.) add 4 plots to the graph's plots collection and a 1D array of data to each respective plot's PlotY method.
- Elton
(3,611 Views)
Elton,
Thank you for your prompt reply.
I have added 4 Plots to the Graphs Plot collection and wish to pass a 1D array of data to each respective plot's PlotY method. Could you tell me what the proper syntax for this is or point me to a document which describes this?
Thank you again,
(3,611 Views)
For example, let's say you have 4 variables called data1, data2, data3, and data4 where each variable is a 1D array. One way would look like this:
CWGraph1.Plots(1).PlotY data1
CWGraph1.Plots(2).PlotY data2
CWGraph1.Plots(3).PlotY data3
CWGraph1.Plots(4).PlotY data4
- Elton
(3,611 Views)
THANK YOU !!!!
(3,611 Views)
