Measurement Studio for VB6
Distribute measurment studio application with opc conntection to field point
I have written an Measurement Studio application with an DataSocket connection to an OPC Sever of an field point 1808. If I distribute this application to another computer I can't get a connection to the OPC Server of the field point. The application works fine on the developent computer of the application. On the other computer is just installed the MAX and the drivers from the Field Point CD. As well I configured the Field Point on that computer. We I browse for an OPC tag in the distibuted application I am not able to access any OPC server, even if I see them. Does anybody have an explanation for that?
Thanks Bernd
(7,357 Views)
Hi Bernd,
you said you were trying to browse the tags from your application. What about MAX? Can you get access to the OPC Server/tags from MAX (can you read out values)?
Do you get any errors, or is it just that you can't access the OPC (but you still see the OPC)?
Please answer me questions, so I can find a solution for you...
Bye
Daniel
NIG
(7,351 Views)
Hi Daniel,
sorry that i answer you so late.  I got an error like "opxproxy.dll could not be found". So meanwhile I checked the system and the opxproxy file was found in the "winnt/system32" directory. After i register the opcproxy.dll manually with the shell command " regsvr32 opxproxy..dll" everything was working fine. Normally, this file should register itself automatically.
Bye
Bernd
(7,324 Views)
Hi Bernd,
thx for the info. I hope everything works fine now and good luck with your project.
Daniel
NIG
(7,314 Views)
