Measurement Studio for VB6
Does DAQmxSetBufInputBufSize() work with Simulated Devices ?
Hi !
I am trying to find the optimum buffer size for my application and I am using the:
Visual Basic 6.0\Analog In\Measure Voltage\Acq-Int Clk example, with a Simulated Device (dev1: PCI-6143).
Now, I want to force the input buffer size to be small enough, so an error will occur.
So, first I change the DAQmxCfgSampClkTiming() function from FiniteSamps toContSamps.
Then, I set the NonOverWrite Buffer Mode and define a small buffer that cannot hold the requested samples.:
    DAQmxErrChk DAQmxSetReadOverWrite(taskHandle, DAQmx_Val_OverwriteMode1_DoNotOverwriteUnreadSamps)
    DAQmxErrChk DAQmxSetBufInputBufSize(taskHandle, numSampsPerChannel / 100)
Why do I not get an error, when running the example ?
Is it a limitation of the Simulated Device ?
Dimitri
(6,579 Views)
Hi Dimitri,
You are absolutely correct: this is a limitation of simulated devices. One thing that I would like to point out is that the DAQmx driver will automatically configure your buffer for you. More information about this is located in the DAQmx Help under NI-DAQmx Key Concepts >> Reading and Writing Data >> Buffering. The NI-DAQmx Help is located in Start >> All Programs >> National Instruments >> NI-DAQ >> NI-DAQmx Help.
Hal L.
(6,559 Views)
