Measurement Studio for VB6
Draw a line on a CWImaqViewer durinq a continuos aCquisition
Can I Draw a line on a CWImaqViewer during a Continuos Acquisition. I Retrieve even the same error:"the object has been locked by an ongoing acquisition and may not be modified"
(6,213 Views)
I'm using NI-IMAQ 2.6.1, Vision 6.1 and a PCI-1407.
I ran the following example installed from the driver:
C:\Program Files\National Instruments\NI-IMAQ\Sample\VB\Grab
and everything worked fine, so I was able to draw lines during the acquisition.
Try with this example to debug your issue.
Regards
AlbertoA
(6,193 Views)
Thank you for your reprly.
But if I try to draw a line by code for example CwImaqViewer.images.overlay(1).Drawline(..) the error occurs.
Please help me!!
Bye
(6,185 Views)
you have duplicate the memory (the image) in which you save the images acquired from the board. Then you can manage the copied buffer (image) with the vision functions (overlay functions you you case).
Regards
AlbertoA
(6,181 Views)
