Measurement Studio for VB6
Editing Annotations problem
I have a problem to move annotations in a graph. (cwui.ocx Version 8.0.11 Release (236) (602))
If there are several annotaions in the graph and I click on a annotation, it can happen that a other annotation is selecteded and moved in the graph.
In the attached test program select the "TrackDragAnnotation" mode and add some MinMaxRegions. Move them around in the graph.
Now edit the corners of some annotations. Move the edge to the maximum and the other to the minimum of the y axis or simply use the "Full Y Range" checkbox. After doing that try to select and move the annotations in the graph. Surprise...
It would be very helpful if there exist a Click event when a annotation is selected. See test program for deleting annotations.
The only way I found is to select the annotation and move or stretch it a little in "TrackDragAnnotation" mode.
In "TrackAllEvents" mode there are the mouse events but you don't see the selected annotation.
Normally in the edit mode there should be also a possibility to delete the selected annotation.
Is there a possibility to change the Z order of annotations? The MinMaxRegion is the only transparent annotation.
I need to see the plot through the annotation (with color filled!) to define certain plot ranges.
The transparent annotation is not fully transparent because they hide other annotations.
Any solutions for that?
For Shapes it will be very helpful if there are 8 points (4 edges, 2 horizontal, 2 vertival) for editing the shape size not only 2.
Is a update avaiable in the future for this?
Message 1 of 1
(6,262 Views)
