Measurement Studio for VB6
Error in starting nidevldu and nipxirmu services (windows event viewer)
A computer running Windows XP SP1 and a Visual basic (V6.0) application that I've developped had crashed several times. I've seen lots of errors in the Windows event viewer saying that the nidevldu and nipxirmu services were trying to start (exact french message : Le service nidevldu est en attente de démarrage et Le service nipxirmu est en attente de démarrage). These messages are real errors (not warning or informations).
I use a 6034E PCI card, Visual basic V6.0 and NI-DAQ 7.4.
The crashes I've seen may be linked with this problem.
Is there a solution?
(8,067 Views)
I think that you are not going to be starting and stopping the devldu service in normal circumstances... due to crashes !
The firsts steps you have to focus on is to optimize your program in order to avoid crashes, which is not a normal way of work I guess. Then you will be able to avoid these messages!
David D. - Application Engineer - NI
(8,056 Views)
