Measurement Studio for VB6
Example of use of decimate function?
Are there any examples of the decimate function from the cwdsp control anywhere?
Or any more detailed help on how to use it or what it does?
I seem to be having a a lot of problems with it.
TIA
Paul
(8,378 Views)
Although I have no experience with this particular control, I've found the following which hopefully may be of use:
An example that uses CWDSP:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=CC109B5C131633FEE034080020E74861&p_node=DZ52130
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3EEA756A4E034080020E74861&p_node=DZ52006&p_source=External
Have you had a detailed look at the documentation in C:\Program Files\National Instruments\MeasurementStudio\Help\cwanalysis.chm
It might be worth posting more info on the type of problems that you are encountering, as well as a description of what you are trying to achieve with the decimate function. It would be handy if you could post your code or at least describe how you are using this function and the parameter values etc.
Stuart
(8,358 Views)
My first problem was just in the general use of the control,
I was expecting it to do an "in place" decimation on the
input parameter, rather than giving the data back as the
return val.
I know I should have read the help more closely,  but a
1 line example of its usage would have made things
immediately more clear.
Subsequent problem was that it keeps failing with an out
of memory error "Runtime error 61706: Insufficient memory
to perform operation", even though there is free memory available
on the PC and I can create a new variable of the same size
with out problem. Code below
Any ideas what I'm doing wrong or just a limit on VB or the controls?
Paul
Option Explicit
Const cBigArraySize As Long = 60000000
Const cSmallArraySize As Long = 30000000
Dim gIntegerArray(cBigArraySize) As Long
Private Sub Command1_Click()
 Dim TempArray() As Long
' TempArray = CWDSP1.Decimate(gIntegerArray, 2, 1)
<-This call always fails
 Dim LoopCounter As Long
 Dim TempArrayIndex As Long
 ReDim TempArray(cSmallArraySize) As Long <-though this always succeeds!
 TempArrayIndex = 0
 For LoopCounter = 0 To cBigArraySize Step 2
    TempArray(TempArrayIndex) = gIntegerArray(LoopCounter)
    TempArrayIndex = TempArrayIndex + 1
 Next LoopCounter
 Debug.Print "IntegerArray(0) = " & gIntegerArray(0) & " a(0) = " & TempArray(0)
 Debug.Print "IntegerArray(0) = " & gIntegerArray(cBigArraySize) & " a(0) = " & TempArray(cSmallArraySize)
End Sub
Private Sub Form_Load()
        gIntegerArray(LoopCounter) = Rnd() * 100
    Next LoopCounter
End Sub
(8,345 Views)
I have experimentally installed, that cBigArraySize can be maximum 36782072.
TempArray should be Variant.
It works:
Option Explicit
Const cBigArraySize As Long = 36782072 '60000000
'    Dim TempArray() As Long
    Dim TempArray As Variant
    Debug.Print "IntegerArray(0) = " & gIntegerArray(cBigArraySize) & " a(0) = " & TempArray(UBound(TempArray))
(8,344 Views)
