Measurement Studio for VB6
Generate Output with Start Triggering
I am hoping to generate a synchronized output signal on PFI1 for each incoming trigger:
scopeSession.ExportedSignals.StartTriggerOutputTerminal = ScopeStartTriggerExportedOutputTerminal.Pfi1
However, I had only a low rep rate trigger output on PFI1 that is out of sync with the incoming trigger signal, as you can see here (yellow trace is the trigger input and blue trace is the PFI1 output. What did I do wrong here?
Thanks in advance.
(3,100 Views)
I think it has something to do with frequency..Try varying frequency...It should solve your problem.U can check guide here myschoolbucks login
(3,080 Views)
