Measurement Studio for VB6
HOW TO CONVERT LOADVALUE INTO VOLTAGE THROUGH DAC.
I am working as a Test Engineer at HAL. I am newly joined person.I want to Test one aircraft test speciman through hydraulic system.i want convert load sat 100 kg into voltage through DAC. Please help me in this issue. i am using bipolar 16 bit card.my reference voltage is 10 v.
(6,788 Views)
Hello.
Thank you for contacting National Instruments.
In order to help you more effectively, I would like to ask you a few questions.  First, what DAQ card are you using?  I understand that it is a 16 bit card, but our boards also have a 4 digit number associated with them.  For example, one of our most popular cards is a PCI-6251.  Can you please provide that information for your card?  Regardless of the card, you should be able to use a load cell to convert the load to a voltage.  For more information on how to use a load cell, please visit the following websites:
Load Cells
How do I Configure a Load Cell in MAX?
Good luck with your application.
Brian F
(6,768 Views)
