Measurement Studio for VB6
Histogram issues
If you run the attached sample you will see that the first bar of the Histogram is very thin and the remaining 9 are as expected. No matter what the 'intervals' is set to, you will get the same result. If the dataset changes you may or may not get this result. I would expect that in my example using 10 as the 'intervals' I would get 10 evenly spaced, evenly wide bars no matter what the dataset. This is a continual problem I encounter. Please tell me what is wrong.
Thank you,
Bob Hiller
(6,240 Views)
And now the attachment!
(6,237 Views)
