Measurement Studio for VB6
How can I access the values in ProfileArray of a CWIMAQProfileReport?
Hi all,
I'm not sure if this is the right board, but I didn't find one related to VB and NI Vision.
I'm using LineProfile2 from CWIMAQVision1 which gives me a ProfileArray which is a variant. I'd like to access the
values in the array. Normally I would do it like
Report(1).ProfileArray(i)
but that does not work. I can get the bounds of the array with LBound and UBound. I can observe the array in
debug modus and it contains reasonable values.
How can I get access to the contents of the ProfileArray?
Thanks in advance
Axel
(6,753 Views)
Hello Alex,
which version of the vision development do you use?
At the moment its not clear for me what is the aim of your application.
Do you want access to the hole intensity values of the 2D array?
You must use the "image to array" function for that.
Please post your email adress so that i contact you directly if its not the correct solution for you.
I will post the feedback for the other customers.
Kind regards,
Elmar
(6,731 Views)
Hi Elmar,
thanks for paying attention to my problems.
I use Vision 8.5. My email adress is axel.wille@izm-m.fraunhofer.de.
I don't need the hole intensity of the image/2D array. I only need the
intensity values of a given line which should be a 1D array of bytes.
I use the following command
        CWIMAQVision1.LineProfile2 Image, Line, Report
When I understood the command correctly the intensity values are
in the Report. I would get them with
But that does not work. I get a runtime error #450.
Other stuff with the report works and gives reasonable values e.g.
            Report(1).PixelCount
            LBound(Report(1).ProfileArray)
            UBound(Report(1).ProfileArray)
Or passing the hole array to plot the values also works
        frmLineProfile.CWGraph1.PlotY Report(1).ProfileArray
Axel
(6,722 Views)
