Measurement Studio for VB6
How do I define a data type as an "IMG_ERR"?
For instance
imaq1394ConfigureAcquisitionCW (sessionId As SESSION_ID, continuous As Long, bufferCount As Long) As IMG_ERR
(8,351 Views)
Dim errorVariable As IMG_ERR
Have you added imaq1394.dll as a reference
Message Edited by CXB on 10-29-2008 02:00 PM
Chris Bolin
LabVIEW Partner Program, CLA
(8,321 Views)
yes, i have added it as a reference
when i type the following
Public Declare Function imaq1394ConfigureAcquisitionCW Lib "imaq1394.dll" (ByVal sessionId As Integer, ByVal continuous As Integer, ByVal bufferCount As Integer) As IMG_ERR
the DE tells me that
'type IMG_ERR is not defined'
(8,282 Views)
Also, is
'-2067990495' a valid session ID number?
(8,280 Views)
Hi Timmkish,
Can you run the "Low Level Grab1394.vbp" example (probably in C:\Documents and Settings\All Users\Documents\National Instruments\NI-IMAQ for IEEE-1394\Examples\VB\Low Level Grab1394)? This example References "NI-IMAQ for IEEE 1394" (imaq1394.dll) and sets a variable to IMG_ERR. It also uses imaq1394ConfigureAcquisitionCW.
Just a snippet...
Dim sid As SESSION_ID
Dim errorCode As IMG_ERR
Dim myImage As New CWIMAQImage
Dim BufferNumber As Long
Private Sub GrabButton_Click()
    CWIMAQViewer1.Attach myImage
    errorCode = imaq1394CameraOpen2(CameraName.Text, IMG1394_CAMERA_MODE_CONTROLLER, sid)
    If (errorCode <> IMG1394_ERR_GOOD) Then
        GoTo Error
    End If
    '  Configure a continuous acquisition (continuous = 1)
    '  using 3 hardware buffers (bufferCount = 3).
    errorCode = imaq1394ConfigureAcquisitionCW(sid, 1, 3)
        GoTo Error
    End If
Message Edited by CXB on 11-04-2008 02:57 PM
Chris Bolin
(8,261 Views)
'-2067990495' should be a valid session ID.  Mine were '-2081623455' and '-2083720607'.
Chris Bolin
(8,252 Views)
