Measurement Studio for VB6
How do I generate a pulse train with IMAQ Vision 6.0 in Visual Basic?
Hello there gurus! I am trying to use IMAQ Vision 6.0 and Visual Basic to generate an external pulse train on my PCI-1408 card. I think I understand more or less how to initialize the signal. I have seen an example in CVI, and the generation of signals seems trivial, however, I don't understand how to do it in VisualBasic. Can any body help me out with this one? The documentation is exceedingly vague in this regard and several of the examples that I have are wrong. 😞
Any pointers would be most appreciated.
Kind regards,
Jason Pickering
jasonp@gintic.gov.sg
(3,499 Views)
Jason -
I have attached a Word document which describes how to configure triggers and generate pulses in VB. However, the PCI-1408 does not support pulse generation. The PCI-1409 is analog frame grabber which does support pulse generation. Here is a link to the product page for the PCI-1409 if you are interested:
http://sine.ni.com/apps/we/nioc.vp?cid=1294〈=US
Jack Arnold
Application Engineer
(3,499 Views)
Thanks for the documents. I finally managed to figure it out after considering the "Triggering" examples. 🙂 Just for to be clear though, the 1408 is capable of some very basic signal generation, like the switching of polarity on a given even (Acquisition Start, Frame Start, etc.). I guess this doesn't really qualify as a pulse train, but for my purposes it is actually sufficient. Thanks anyway for your help!
(3,499 Views)
Yes, you can drive internal board signals such as Acq. Start and Frame Start on the trigger line with the PCI-1408. You can also have all the triggering functionality of the board. The only feature not available is the pulse train generation.
Hope this helps.
Jack Arnold
(3,499 Views)
