Measurement Studio for VB6
How do I manually UNregister type libraries (.tlb)
I thought I could, using regtlib.exe, but I have not find a way yet
(19,852 Views)
Newer versions of regtlib.exe have a -u switch that will let you unregister type libraries. If your version of regtlib.exe doesn't support this switch and you can't find a newer version, you can also do it with this utility:
http://www.vbaccelerator.com/codelib/tlb/vbregtlb.htm
Or this utility:
http://www.mvps.org/btmtz/_misc/regtypelib.zip
- Elton
(19,852 Views)
Here's a link to a KB that addresses registering and unregistering ActiveX controls and type libraries in Windows.
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/4f811a9b23f1d46e862566f700615b7a?OpenDocument
Good luck.
(19,852 Views)
It is talking only about registering and not unregistering. Older versions of regtlib.exe do not support unregistering type libraries.
(19,852 Views)
Hi gd047,
Try this link:
http://www.freevbcode.com/ShowCode.Asp?ID=2195
It contains info on registering and unregistering type libraries. Hope this helps.
Good luck.
(19,852 Views)
Thank you very much
You might be interested to the answer that Elton Wells gave to my question
(19,852 Views)
