Measurement Studio for VB6
How do I program VB6 to output a simple steady state analog signal?
I am new to both VB6 and NI-DAQmx and I am trying to get my PCI-6722 ("Dev1") to write a steady state anaolog signal to the ao0 output upon  a command.  With the following code, I am trying to have it output 1 volt to ao0 but keep getting the erro code "Run-time error '-200077 (fffcf273)': Measurments: Request value is not a supported value for this property."
I'm sure I'm doing something wrong, but I'm not sure what it is.  Any suggestions?
Private Sub Command10_Click()
Dim taskHandle As Long
DAQmxErrChk DAQmxCreateTask("", taskHandle)
DAQmxErrChk DAQmxCreateAOVoltageChan(taskHandle, "Dev1/ao0", "", 0, 5, DAQmx_Val_Volts, "")
DAQmxErrChk DAQmxWriteAnalogScalarF64(taskHandle, 1, 10#, 1#, "")
(7,092 Views)
nevermind. I got it!
(7,077 Views)
