Measurement Studio for VB6
How to avoid flickering in CWGraph when click it
I am using CWGraph control to plot and analysis data on a VB6/sp4 application(windows 2000). The data will be updated about every 0.5 second with maximum points about 1500. Everything works well except every time when user click CWGraph or user try to pan/zoom it, it is flashing. When the control is resized, flashing stops. I tried with immediateupdate, windowless,refresh etc. properties, but still doesn't work. Any suggestion will be appreciated.
(3,208 Views)
I have heard of this behavior before as you may have noticed in a few other users' posts, but since it is not readily reproduceable in house we have come to a general concensus that the cause must be a combination of some of the following suspects in your current setup:
1) An underpowered machine (i.e. a pentium classic with 32MB of RAM running Windows 2000)
2) A graphics display problem (outdated driver or a generally suspect brand of video card)
3) Too many other processes running at the same time as your Visual Basic application.
I know that these types of issues are often discouraging because of their random nature, but realistically they cannot be fixed by the developers if they are not reliably reproduceable so that the exact cause can
be pinpointed. This is why we are led to believe that it is some combination of system setup issues that is causing this.
If you are running a system that is "underpowered" for its current software setup, there really isn't much you can do except try to see if you can move to another, more powerful machine. As for the graphics subsystem you should always try to see if the latest driver for your video card resolves the problem. Regarding system performance as well, you should check to see if you have other unnecessary processes running that are inherently slowing down your system. Lastly, one thing you should also try is see if a somewhat similar system exhibits the same behavior so that you can use it as a test case to figure out what is causing the problem in your current system.
Jason F.
www.ni.com/ask
(3,208 Views)
