Measurement Studio for VB6
How to cancel default cursor on CWIMAQViewer?
How to cancel default cursor on CWIMAQViewer when I attach an image to CWIMAQViewer? i.e. I want to use arrow cursor to replace it and I don't want have any function of CWIMAQViewer.Such as push the left mouse key down and so on.
(3,072 Views)
If you want to select arrow as cursor you need to call the following line in your code:
CWIMAQViewer1.Tool = cwimaqToolSelection
If you also want to disable right click menu items, call the following:
CWIMAQViewer1.MenuItems = 0
Hope this helps
Yusuf C.
Applications Engineering
(3,072 Views)
