Measurement Studio for VB6
How to configure PCI-6025E input channel terminal in NRSE mode using DAQmax8.5
How to configure PCI-6025E input channel terminal in NRSE mode using DAQmax8.5. Tried to use "DAQmx_Val_NRSE " alias as an argument in DaQmaxCreateAIVoltageChan Command but DaAQmax did recognize it.
(6,737 Views)
 Hi MoShaz,
 I just tested the following code and it should work for you. Here's a screenshot of the code:
Please give this a try! Best regards,
MatthewW
Message Edited by Matthew W on 09-20-2007 03:05 PM
(6,721 Views)
