Measurement Studio for VB6
How to generate 3dSurface plot starting from x,y,z txt file
Hallo guys,
I need to generate a 3Dsurface plot starting from unordered coordinates data available in the following
text file:
xs,   ys,   zs
-20,-70,1500
-30,-55,1500
-30,-79,1500
-40,-70,1500
-10,-70,2000
-30,-42,2000
-30,-90,2000
-53,-70,2000
-5,-70,2500
-30,-30,2500
-70,-70,2500
-30,-100,2500
I tried with 3DMesh using the following VB6 code (without valuable results):
[code]
rsurf.Open "Select * From surf.txt", _
       connCSV, adOpenStatic, adLockReadOnly, adCmdText
l = rsurf.RecordCount
surflbl.Caption = "records" & l
ReDim xs(l), ys(l), zs(l)
For i = 1 To l
            xs(i) = rsurf.Fields(0) 'EW (m)
            ys(i) = rsurf.Fields(1) 'NS (m)
            zs(i) = rsurf.Fields(2) 'DEPTH (m)
            rsurf.MoveNext
Next i
rsurf.Close
connCSV.Close
CWGraph3D1.Plot3DMesh xs, ys, zs
[/code]
When i try to convert 3dmesh into 3dsurface, in order to have a smooth surface, i really don't know how to  build the zs(i,j) matrix
I don't know, further, why data displayed on the plot always start from 0,0,0 coordinates
Any help and example would be very appreciated
Beta66
(7,368 Views)
Hy
maybe this question is not so appealing, but i would have really appreciated any suggestion  on how to built a 3dsurface grid starting from  x,y,depth data on a txt file
thanks
beta66
(7,323 Views)
If your still interested I had some luck doing this....
Dim xs, ys, zs As Variant
Dim j
Dim ArrX(0 To 11) As Double
Dim ArrY(0 To 11) As Double
Dim ArrZ(0 To 11) As Double
xs = Array(-20, , -30, -30, -40, -10, -30, -30, -53, -5, -30, -70, -30)
ys = Array(-70, -55, -79, -70, -70, -42, -90, -70, -70, -30, -70, -100)
zs = Array(1500, 1500, 1500, 1500, 2000, 2000, 2000, 2000, 2500, 2500, 2500, 2500)
For j = 0 To 11
    ArrX(j) = CDbl(xs(j))  'I don't know why but this type cast was required
    ArrY(j) = CDbl(ys(j))
    ArrZ(j) = CDbl(zs(j))
Next j
CWGraph3D1.Plot3DMesh ArrX, ArrY, ArrZ
good luck with your project
Curt
(7,275 Views)
hi curt c
The code you kindly submitted is, actually, similar to the one I'm already using. Infact both codes use the method 3dmesh. What i would use is the method 3dsurface or 3dsimplesurface in order to plot contourlines on the surface, but the problem is that I don't know how to built the z(i,j) matrix from available "z" data present on txt file.
Beta66
(7,261 Views)
