Measurement Studio for VB6
How to read data from Communication port RS232 or DB-25 In Visual Basic ?
I Have problem with read data from communication port thru Visual Basic program
please, answer with Example Code
Thank's
ADI GERIMU
(3,946 Views)
Hello adigerimu,
If you are using National Instruments ComponentWorks (Tools for Visual Basic) package, you can find serial examples located at "C:\MeasurementStudio\VB\Samples\Instr\Basic Serial" or wherever you installed Measurement Studio. We also have an example that uses VISA online at http://zone.ni.com then click RESOURCE LIBRARY >> COMPONENTWORKS >> GENERAL and look for links that mention "serial". If you are not using ComponentWorks, then this is not the appropriate newsgroup for your question, and I would recommend you start by looking at http://www.msdn.microsoft.com.
Jeremiah Cox
http://www.ni.com/ask
(3,946 Views)
