Measurement Studio for VB6
How to reduce the width of the graph frame?
Colleagues,
By default, CWGraph has a frame between the actual charting area and the edge of the component.  Is there a way to control the width of this frame?
-Nick
(6,889 Views)
Hi Nick,
Are you talking about the changing the frame width itself or increasing the size of the chart area?
Thanks!
Chris T.
(6,873 Views)
Hi Chris,
Either way could work.  My program will run on a small display, so I need to jam as much chart as possible into it.  Since frames don't carry information per se, I'd like to "waste" as few pixels as possible on them.
- Nick
(6,837 Views)
Hi Nick,
I couldn't find anything in particular to changing the graph area directly, but I did notice the classic frame style has much less wasted space.
try...
CWGraph1.GraphFrameStyle = cwGraphFrameClassic where CWGraph1 is the name of the CWGraph object.
Hope this helps!
Chris T.
(6,825 Views)
