Measurement Studio for VB6
How to set & use digital trigger for AIN on a DAQmx?
1) How I configure a task to allow a digital input line to trigger a AIN reading in VB6.0 with a USB-6210?
2) To help me answer the above I created a task in Measurement & Automation Explorer that used a digital trigger (TRIGGER TYPE= DIGITAL EDGE, TRIGGER SOURCE = PFI0, EDGE=RISING).  Then from VB I tried to figure out the parameters that were set.  I had no luck.  So, once I understand to achieve (1) above I want to be able to verify the resulting settings.  What command(s) would I use?
(6,555 Views)
Hi Hjehan,
I recommend checking the following knowledge Base that can point you to the different DAQmx examples.
Faris A
Bueller
(6,524 Views)
