Measurement Studio for VB6
How to use ComponentWork CWSerial to program such thing like HyperTerminal does to communicate 2 PCs through its RS232?
Right now I use null modem cable, I can communicate 2 PCs use hyper-terminal. I wonder how to use ComponentWork CWSerial to program such kind of job? Thanks!
(3,068 Views)
Hi Kevin,
Of course this will take a little work, but CWSerial should be able to handle this without too much hassle. Take a look at the example program usually included in C:\Program Files\National Instruments\MeasurementStudio\VB\Samples\Instr\Basic Serial
You should be able to use this example as a starting point.
Hope this helps out!!!
Best Regards,
Aaron Kobayashi
Application Engineer
(3,068 Views)
