Measurement Studio for VB6
I observed CWUI6.0 is slower than CWUI3.0 in drawing the graph
I had CWUI3.0 earlier and the graph is faster, with the same VB code I tested the CWUI6.0 (Measurement Studio 6.0) the graph display is slower is there any setting that will improve the speed of the displaying the graph.
I thank you in advance.
Shiva
(3,168 Views)
Here are a few things to try:
  • Change the GraphFrameStyle property from cwGraphFrame3D (the default value) to cwGraphFrameClassic.
  • Set the ImmediateUpdates property to False.
  • Set the Windowless property to True.
Give these a shot and let me know how it works out.
- Elton
(3,168 Views)
Hi Elton,
Thank you for the suggestion. I had the GraphFrameStyle set to cwGraphFrameClassic, but I did changed the ImmediateUpdates property and the Windowless property.
I am impressed by the performance.
Shiva
(3,168 Views)
