Measurement Studio for VB6
I want to use the analog trigger pulses to give a 10% duty cycle pulse every half cycle of the sine wave that i am outputing from DAC0.
I want to use the analog trigger pulses to give a 10% duty cycle pulse every half cycle of the sine wave that i am outputing from DAC0. In order to get good accuracy at high frequencies and very good accuracy at lower freqencies (<0.25Hz below 500Hz) i have had to fit differing numbers of waveforms into the buffer so that some cycles in the buffer have 100 samples, say, and others have 101. If I use a standard pulse train then a drift between the pulses and the waveform is observed unless there is only 1 waveform in the buffer. For this reason I would like to feed the output back into the input and trigger off it in "Inside Window" mo
de at the appropriate trigger level to give roughly 10% duty cycle.
I see that there are example VI's (How to use the analog trigger circuitry output as an external signal) but cannot find an example using VB and Component Works.
I am attempting to use RouteIOSignal to route ATCOUT to various PFI pins and even GPCTR0 but with no success. Error message states "Invalid Numeric Value"?
(5,552 Views)
Martin
One thing you can try is to use your analog trigger to trigger a counter and have the counter generate a pulse.
(5,552 Views)
how can counter decrements of vb6 , plus from comport ,external plus.
(4,394 Views)
