Measurement Studio for VB6
In my program CWNumEdit shows 14,5 when I write 14.5.
In my program CWNumEdit shows 14,5 when I write 14.5. I would like the control to show decimals as dots. How do I solve this problem_
(3,531 Views)
There is no setting I know of in CWNumEdit that allows you to set the format like this. We do have several format strings you can set under the FORMAT TAB on the property pages for the CWNumEdit.
I think you may have to change the Regional Settings under your Windows OS. This can be done through the control panel. Depending on the language you select, numbers can be represented in different formats.
Daniel McChane
Application Engineer
(3,531 Views)
What is the locale of the machine that you see this on? You can find the locale setting by going to Control Panel, selecting Regional Options, and look under "Your locale" under the General tab.
- Elton
(3,531 Views)
The locale settings of my computer is: English(USA).
//Ulrika
(3,531 Views)
What are the decimal symbol and digit grouping symbol settings under the Numbers tab? Also, what are the decimal symbol and digit grouping symbol settings under the Currency tab?
- Elton
(3,531 Views)
Here is the settings under the Numbers tab.
Decimal symbol: .
Digit grouping symbol: ,
Here is the settings under the Currency tab.
Decimal symbol: .
//Ulrika
(3,531 Views)
