Measurement Studio for VB6
Including LLB contents in an Executable
I'm using LV 8.5.
I have a number of LLBs. The VIs in these LLBs are called dynamically by other VIs within the project, so I want them explicitly included within the executable.
When I add the LLBs to the project, I can add it as a snapshot and see the contents spilled out in tree view. if I add it as an auto-populating folder, it does not expand to view the contents.
I build the Application and attempt to run it.
If I included the LLB as an auto-populating folder, the contents of the VIs are NOT included in the executable. I know this because the VIs I attempt to call dynamically are not found.
If I included the LLB as an snapshot folder, the contents of the VIs appear to be in the executable; there are no 'path/VI not found' errors.
Q1? : Is it possible to have an auto-populated LLB?
Q2? : If not, would you please pass it as a requested feature for 8.5.1?
Thank you.
(6,765 Views)
In what case would you want to have an autopopulating library? Are you constatly rebuilding that library with new VIs in it?
Nick R
NI
(6,754 Views)
In short, yes. They will be updated from time to time.
Regardless of my particular use case, having llbs treated the same as folders would be convenient -- they seem to be in many other regards anyway.
(6,752 Views)
