Measurement Studio for VB6
Install / Configuration usb-6218 for vb6 ?
I'm trying to execute an example about DAQ. I want to reveive data but I can not select the device. I have read its necessary intalling and configuring the device but I think  this is yet realized because this device appear in MAX and operate correctly.
I attach a picture about the error.
Thank you
antonioSotelo
Message 1 of 10
(10,033 Views)
Hi Antonio,
I found information acording your description.
What kind of Software are you using? Windows XP with Service Pack 1 or 2? Visual Studio Service Pack 3?
It seems that there is a inference between this two. If this is the cause of the problems, the solution would be to deinstall Visual Studio and reinstall it without the Service Pack 3. After this installation is complete, your DAQ board should show up in the CWAI device list.
I hope this helps to solve the problem.
Mona
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
Message 2 of 10
(10,024 Views)
Hola otra vez,
I was searching more and found a other possiblity for this behaviour. If you have installed NI-DAQmx I believe this is the reason much more likly.
M-series boards are supported by DAQmx drivers, and Visual Basic 6.0 support Traditional DAQ only. The work around for this is to upgrade your software to Visual Basic. NET which supports DAQmx.
So the upgrade would reslove the problem!
Greeting!
Ramona Lombardo
Message 3 of 10
(10,022 Views)
Thank you for you response. I unistalled servic pack 3 of visual basic but it did not work. We can not chage to .net because we use other application in Visual Basic so we continuing search other alternative.
Thank you.
antonioSotelo
Message 4 of 10
(10,001 Views)
Hi Antonio,
I got new information.
As I told you this error seems to be the NI-DAQmx incompability. So the newest verion 8.6 is now compatible with Visual Studio Service Pack 6!
So I recommend to update Visual Studio to SP6 and install NI-DAQmx 8.6:
http://joule.ni.com/nidu/cds/view/p/id/833/lang/en
In the Readme-file you see, that Visual Studio supports DAQmx 8.6 and you device.
I hope this helps!
Greetins
Ramona Lombardo
Message 5 of 10
(9,997 Views)
I installed Visual Studio 6.0 and service pack 6 (not more service pack). Then, I installed NI-DAQmx 8.6  but it doesn`t work. Do you have any tutorial to help me?
I have been trying to execute the samples but the device usb6218 is not detected..
Thank you for all.
Mensaje editado por antonioSotelo
antonioSotelo
Message 6 of 10
(9,966 Views)
Hi!
Can you see the card in MAX?
RMathews
Ramona Lombardo
Message 7 of 10
(9,962 Views)
Yes, I can. I can receive and send data through MAX and labView. And I can create a task in Max and execute it with Visual Basic 6.0 but i can not use the control in Visual Studio 6.0 to create the task. I need only use Visual Studio without the task made in Max.
Thank You.
antonioSotelo
Message 8 of 10
(9,959 Views)
ok, the problem seems to be that the examples in VS 6 are for the trad. DAQ and wont work with DAQmx.
Here you have a link for DAQmx examples for Visual Studio. I think this will resolve the problem:
http://digital.ni.com/public.nsf/allkb/735848148B5B4964862571F5004692C7?OpenDocument
Greetings,
Mona
Ramona Lombardo
Message 9 of 10
(9,956 Views)
Ok, im going to probe this. I will respond when i have a result.
Thank you again
antonioSotelo
Message 10 of 10
(9,954 Views)
