Measurement Studio for VB6
Is it possible to generate Sine wave from card on Graph
As I have seen in Test Panel of Ni that we can generate sine wave.
Is it possible to generate Sine wave from card and show graph on our VB application (Not Test Panel).
If it is possible then please send me the pin coneection for card and what I have to write in my code.
I am using pci 6025-e daq card with its 50 pins input board, and my application development plateform is Visual basic 6.0.
Please guide...
Thanx in advance..
(3,007 Views)
If you want to generate a sine wave from your card, just use the CWDSP control's SineWave function and then send that waveform to an analog output channel on your board with the CWAO control. If you want to also plot the sine wave on the graph, then just use the PlotY function with the data generated from the SineWave function.
Best Regards,
Chris Matthews
(3,007 Views)
