Measurement Studio for VB6
Is it possible to have vertical traces in measurement studio for visual basic?
I want to have a strip chart running from the top down in Meas Studio, VB. Actually, would like 8 separate graphs. Can it be done?
(3,117 Views)
There isn't an easy way to do it. You can fake it by setting the ChartLength property to how much data you want to display at a time, maintaining your current Y position, and using the ChartXvsY method. For example, create a new VB project, drop a graph and a timer on the form, and copy the following code into the project:
Private chartYValue As Double
Private Sub Form_Load()
Timer1.Interval = 100
CWGraph1.ChartLength = 50
chartYValue = 0
End Sub
Private Sub Timer1_Timer()
CWGraph1.ChartXvsY Rnd * 10, chartYValue
chartYValue = chartYValue - 1
End Sub
What's really happening is that the graph is getting up to ChartLength number of points and as additional data is added, the Y axis autos
cales, but the visual side effect is that it looks like it's vertically charting data from top to bottom.
Hope this helps.
- Elton
(3,117 Views)
