Measurement Studio for VB6
Join images
HI, my machine has two cameras with the same resolution. The field of view is partially overlapped. I have to join the 2 images. I know I could do it using the IMAQ Image to Image but in this case I will have a finel image with the area of overlap doubled.
Is there any tool or function that help me to join 2 images without any doubled area?
I have several machines, hence I would like to find a sw solution for this problem. I try to have the same optical settings for all the machines but they will be never really identical.
Is there a function that allows me to calculate a linear pattern matching? I mean, do a pattern matching between two rows or columns( more general between two arrays.
Thanks.
(6,738 Views)
I'm Matteo, from NI!
I want to suggest you the IMAQ Merge Overlay function. Spend some time to take a look of it! 🙂
Cheers
Matteo
Matteo Brunella
Application Engineer
NI Italy
(6,724 Views)
Sorry, I do not know how but I posted this message into the wrong forum. I have already posted in the Machine
vision forum.
(6,721 Views)
